williaml392
#1 Posted : Friday, September 4, 2009 8:07:31 AM(UTC)
williaml392
I have a Speed Queen Model # AEM497W. When I hit the on button it just buzzes. If I "help" the tumbler and shut the door quickly it will work. Is the motor "going" bad?? If so, is there some way to check it?? HELP!!!
sidfink43
#2 Posted : Saturday, September 5, 2009 12:57:11 PM(UTC)
sidfink43
Your symptons are exactly those of a motor that is in the process of failing.
No gurantees but a motor replacement should solve your problem.
Good luck.
