I have a Speed Queen Model # AEM497W. When I hit the on button it just buzzes. If I "help" the tumbler and shut the door quickly it will work. Is the motor "going" bad?? If so, is there some way to check it?? HELP!!!
Your symptons are exactly those of a motor that is in the process of failing.
No gurantees but a motor replacement should solve your problem.
Good luck.
