boobert74
#1 Posted : Thursday, September 3, 2009 4:05:26 PM(UTC)
boobert74
i just bought a new high limit thermostat for my dryer and i noticed that the heating element stays on all the time and glows red hot,I thought it was supposed to kick off and on and not stay on all the time,did i buy the wrong thermostat???????
Drags1998
#2 Posted : Thursday, September 3, 2009 4:26:56 PM(UTC)
Drags1998
If the heater stays on ALL THE TIME, The problem is either the cycling thermostat, or the heater is grounded to the heater can!!!! NOT THE HIGH LIMIT THERMOSTAT. Be careful, your looking for a FIRE if you keep it up!!!:eek:
kilzem
#3 Posted : Sunday, October 4, 2009 1:35:27 PM(UTC)
kilzem
I'm just wondering if I have a grounded out Element, my symptoms seem similar to the first post.
The very second power is connected to the Dryer the Element begins to heat up. I let it get really hot (maybe too hot) before turning off the breaker. It was clear that the Overheat Protector was not stopping it.
If this is a ground out, is there a way I can fix this, or will I have to buy a new Element?
Thanks,
William
Fridgidaire FE0332CES0 Dryer
#4 Posted : Monday, October 5, 2009 3:18:08 AM(UTC)
Check first to see if this is your problem.
Unplug the unit.
Remove both wires from the heating element.
Measure the element for resistance, usually around 10 ohms.
Then measure from each connector to the case/frame, both should be open (infinite ohms)
If it is grounded remove and inspect it.
Sometimes the element has just sagged and is touching the case.
More often it has broken or has sagged and is welded to the case which means you need a new element.
Kenmore 100 dryer Heating Element (Dryer Repair)
by postalservice21 3/27/2024 6:43:17 AM(UTC)
Dryer Heating Element Stays on during cool down and air dry (Dryer Repair)
by Ron.Easterling 10/9/2017 2:16:54 PM(UTC)
dryer heating element is drying very hot burning cloths and wont turn off (Dryer Repair)
by lulabell52655 4/20/2017 3:22:26 AM(UTC)
Kenmore Dryer Heating Element (Dryer Repair)
by alex1968 8/8/2016 10:11:49 AM(UTC)
dryer heating element (Dryer Repair)
by skl 2/18/2016 6:10:34 PM(UTC)
Dryer heating element always on (Dryer Repair)
by Donth 4/22/2015 9:37:29 AM(UTC)
Whirlpool cabrio steam dryer heating element replacement (Dryer Repair)
by Redskinfanatic 2/3/2015 4:11:38 PM(UTC)
Maytag dryer heating element glows red after opening the door (Dryer Repair)
by Pfc30a 1/7/2015 4:24:35 PM(UTC)
Kenmore 70 Series Dryer Heating Element (Dryer Repair)
by VSimon10 3/6/2014 2:19:25 PM(UTC)
Dryer Heating Element wont shut off When Dryer vis off (Dryer Repair)
by scottxbonnie 7/30/2012 10:14:06 PM(UTC)
by spt 4/1/2012 12:20:08 PM(UTC)
whirlpool cabrio dryer heating element repair (Dryer Repair)
by bradman67 3/17/2012 11:02:03 AM(UTC)
Dryer heating element (Dryer Repair)
by myelken@yahoo.com 2/22/2012 6:49:58 PM(UTC)
Dryer heating element keeps burning out! (Dryer Repair)
by bountyhunta5000 1/14/2012 9:33:31 AM(UTC)
dryer heating element watt (Dryer Repair)
by williebrownlee 1/4/2012 8:52:17 AM(UTC)
