My Frigidaire dishwasher (Model GSB5755DS) is taking forever to finish on the light cycle. When I start the display reads 89 (this is for 89 minutes) then it jumps down to 54 (54 minutes) a short time after that the display will read HO. The cycle then may take up to 3 hours to complete. My hot water is very hot so I'm wondering if it is the hot water sensor. Has anyone run into this before?
Did you ever get a fix for this? My DW does the same thing. We just started running it at night since it takes SO LONG. i just accepted it as a fluke, but I would really like to fix it. I even turned my water heater up. No difference.
Anyone, Brad
Anyone? It's been a while, but I thought I would ask again.
THIS FORUM IS DEAD!!!!!!! |
Thank you so much. I will see what I can do from there.
Thanks again.
