DaleHurd
#1 Posted : Saturday, January 19, 2008 11:00:04 AM(UTC)
DaleHurd
My Frigidaire dishwasher (Model GSB5755DS) is taking forever to finish on the light cycle. When I start the display reads 89 (this is for 89 minutes) then it jumps down to 54 (54 minutes) a short time after that the display will read HO. The cycle then may take up to 3 hours to complete. My hot water is very hot so I'm wondering if it is the hot water sensor. Has anyone run into this before?
bradford
#2 Posted : Wednesday, December 24, 2008 11:56:47 AM(UTC)
bradford
Did you ever get a fix for this? My DW does the same thing. We just started running it at night since it takes SO LONG. i just accepted it as a fluke, but I would really like to fix it. I even turned my water heater up. No difference.
Anyone,
Brad
bradford
#3 Posted : Sunday, December 28, 2008 5:57:29 PM(UTC)
bradford
bump. Anyone?
bradford
#4 Posted : Wednesday, March 3, 2010 1:09:39 PM(UTC)
bradford
Anyone?
It's been a while, but I thought I would ask again.
#5 Posted : Wednesday, March 3, 2010 1:56:50 PM(UTC)
Replacement parts for GSB5755DS models | AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Kinston/154476701.pdf
And here is the closest thing I could find in a manual
http://frigidaireservicetips.com/pdfs/484_2.pdf
If they use the same thermistor which is likely, it should be 10,000 ohms at 77 degrees F.
I would also check the heating element and the hi-limit thermostat.
bradford
#6 Posted : Thursday, March 4, 2010 6:02:31 AM(UTC)
bradford
Thank you so much. I will see what I can do from there.
Thanks again.
