I was heating up a cup of water for tea yesterday and it warmed up somewhat and then the unit went totally dead. I have been reading the forum and my only concern is that I am getting the correct fuse. The instructions seem to show it in a different area then where mine is (I believe mineis). It is on a circuit board at the back of the microwave. The power cord runs out the the board. Next to the fuse it say "Special Fuse F1". Is this the fuse I need to check out to see if it is bad? Thanks for your input.
John
Originally Posted by: Johndgay I was heating up a cup of water for tea yesterday and it warmed up somewhat and then the unit went totally dead. I have been reading the forum and my only concern is that I am getting the correct fuse. The instructions seem to show it in a different area then where mine is (I believe mineis). It is on a circuit board at the back of the microwave. The power cord runs out the the board. Next to the fuse it say "Special Fuse F1". Is this the fuse I need to check out to see if it is bad? Thanks for your input.
John Power board metal oxide baristas blown and 15 amp Fc2fuse blown
Originally Posted by: Tsread Power board metal oxide baristas blown and 15 amp Fc2fuse blown . I do not see a "power metal oxide barista" listed for any of the parts in the Microwave. Also, the appliance list only shows 1 fust so I guess that must be it. Please clarify regarding the "power board metal oxide barista". It sounds expensive. JohnDGay
