jotisch
#1 Posted : Wednesday, September 2, 2009 9:10:50 AM(UTC)
jotisch
Our dishwasher will not run in any of the wash cycles, sometimes the Delay Hours light would stay on or blink and you could get it to run in Normal Cycle if you played with the door switch long enough, so we finally replaced with the "Door Switch Repair Kit" that didn't change anything. So we recently replaced the "Electronic Control Assembly" and still it won't wash, but now the "Rinse Only" "China" and "Cancel/Drain" buttons are all flashing.
We are thinking the next step might be the Thermal Fuse, but since we have lights on the front didn't know if that would be necessary. At this rate if we keep trying these things we could have paid for a new one!! Please help, any suggestions as to what to do next?
Jo
#2 Posted : Wednesday, September 2, 2009 4:56:52 PM(UTC)
Hi Jo,
Sounds like the problem is a bad key pad and it was probably wrong from the beginning. The part number for the control panel are different for different colors as you can see from the parts diagram: Replacement parts for WHIRLPOOL GU940SCGB2 | AppliancePartsPros.com
jotisch
#3 Posted : Monday, September 28, 2009 6:50:24 PM(UTC)
jotisch
Gene,
Thanks so much for the advice, that was the problem. We are up and running now. Thanks again.
Jo
#4 Posted : Tuesday, September 29, 2009 5:05:26 PM(UTC)
You are welcome. I'm glad to know you are back in business.
Dishwasher won't run cycles, only fills a bit (Dishwasher Repair)
by Snowfinch 7/7/2015 7:06:10 AM(UTC)
Kitchenaid Dishwasher won't run ? motor (Dishwasher Repair)
by garywool93 8/30/2013 1:23:19 PM(UTC)
Dishwasher won't run (Dishwasher Repair)
by thebling 2/21/2013 9:37:53 AM(UTC)
Whirlpool GU1500XTLT Dishwasher Won't Run (Dishwasher Repair)
by fishingbear 5/5/2012 8:15:09 AM(UTC)
Dishwasher Won't Run/Air Dry Light Flashing (Dishwasher Repair)
by Coyote1cf 1/16/2012 10:42:09 AM(UTC)
KitchenAid dishwasher won't run (Dishwasher Repair)
by johnniered 12/30/2010 9:26:32 AM(UTC)
GE Dishwasher won't run (Dishwasher Repair)
by Logan29 11/21/2010 5:55:12 PM(UTC)
Dishwasher won't run full cycle (Dishwasher Repair)
by Jp4me 8/15/2010 10:27:10 PM(UTC)
Dishwasher Won't Run/Drain (Dishwasher Repair)
by k5sparks2 2/17/2010 12:05:43 PM(UTC)
KitchenAid Dishwasher Won't Run (Dishwasher Repair)
by john roberts 9/14/2009 3:10:11 PM(UTC)
by RJB 5/2/2009 6:38:56 AM(UTC)
Kitchen Aid Dishwasher won't run cycle (Dishwasher Repair)
by mscoop 4/29/2009 6:45:10 PM(UTC)
Whirlpool dishwasher won't run (Dishwasher Repair)
by AmateurTech 3/15/2009 6:48:20 AM(UTC)
frigidaire dishwasher won't run (Dishwasher Repair)
by utahskierdave 1/18/2009 10:40:58 AM(UTC)
Dishwasher won't run - "Normal" light flashing (Dishwasher Repair)
by awright 11/3/2008 8:53:26 PM(UTC)
