Mnelson23
#1 Posted : Friday, April 13, 2012 2:18:35 PM(UTC)
Mnelson23
My Gibson Quiet Clean Plus has recently leaked all over the floor. It appears to be coming out of the float. When leaking, it runs across the bottom of the dishwasher. Any ideas as to what part in particular may be leaking? Thanks.
#2 Posted : Saturday, April 14, 2012 2:56:30 AM(UTC)
You have to locate the leak.
Remove the kick plate and track it back to it's source.
A small mirror and a flashlight can help here.
Remove the float and check that it is clean.
Sometimes they can get crud in them and this can cause a leak due to capillary action. But your post seems to indicate that there was lots of water so I doubt this is the cause.
Check for a crack around it.
Does the unit drain completely?
Is the unit level?
Was there lots of suds when it leaked?
Does it leak every cycle?
If you find the cause be sure to leave the kick plate off for several days so it will dry out underneath otherwise your floor will rat.
If you have small kids or pets be sure to unplug or remove power from the unit.
GSD5120D00BB GE dishwasher leaking at the bottom corners (Dishwasher Repair)
by ron Minervino 12/7/2023 9:15:11 AM(UTC)
Dishwasher Leaking Kitchenaid KDTE334DSS0 (Dishwasher Repair)
by Bscott46 10/4/2022 5:16:08 PM(UTC)
Maytag dishwasher leaking and smoking (Dishwasher Repair)
by Guest 10/19/2021 2:58:51 PM(UTC)
LG Dishwasher Leaking When First Turned On (Dishwasher Repair)
by artriumph 4/22/2021 1:13:56 PM(UTC)
Maytag Dishwasher LEAKING underneath (Dishwasher Repair)
by bakerid2000 9/5/2019 5:49:20 PM(UTC)
Whirlpool dishwasher leaking bottom (Dishwasher Repair)
by nkaufman1 5/14/2019 1:50:41 AM(UTC)
Bosch Dishwasher Leaking into base (Dishwasher Repair)
by Canadianice 4/12/2018 8:18:35 AM(UTC)
Dishwasher leaking underneath [PHOTOS] (Dishwasher Repair)
by jd514 1/6/2018 11:16:52 AM(UTC)
Kitchenaid dishwasher leaking under door (Dishwasher Repair)
by chasethedream 1/1/2017 8:30:50 AM(UTC)
Dishwasher leaking from motor area (Dishwasher Repair)
by jay143 11/1/2016 12:20:29 PM(UTC)
Dishwasher Leaking (Dishwasher Repair)
by alanwoodbury 9/26/2016 10:47:47 AM(UTC)
whirlpool dishwasher leaking from door (Dishwasher Repair)
by pburd89 2/19/2016 1:36:17 PM(UTC)
Kitchenaid dishwasher leaking (Dishwasher Repair)
by steve80124 9/21/2015 2:15:04 PM(UTC)
Dishwasher leaking from sides and detergent sometimes solidified (Dishwasher Repair)
by luked3 4/9/2015 7:03:05 AM(UTC)
dishwasher leaking from bottom (Dishwasher Repair)
by kjack45 12/8/2014 8:06:43 AM(UTC)
