w.potaris@verizon.net
#1 Posted : Tuesday, September 1, 2009 3:55:41 PM(UTC)
I have replaced the following parts and I still have a screeching sound when dryer operates:
1 of AP2621911 (WE1M462) - Sleeve drum
1 of AP4324040 (WE12M29) - Dryer drive belt
2 of AP631382 (WE1M481) - Slide, Drum
2 of AP2041815 (WE1M333) - Dryer drum slide
1 of AP3794707 (WE4M305) - Lamp
1 of AP3790641 (WE3M26) - Front drum bearing
I noticed that there is no sign of the O-ring that is listed as part number 3127 - O-ring
Part Number: AP2621539
made by GE
Could this be the problem or do you think it may be the complete bearing? There is no sign of wear or wobbling on the shaft. Only the sleeve was slightly chewed up.
Your thoughts....?
sidfink43
#2 Posted : Friday, September 4, 2009 10:39:52 AM(UTC)
sidfink43
Sounds like that o ring may have been chewed up.
It is almost impossible for a Forum like this to diagnose a noise because we are not there to listen to it. On these machines I generally replace all the part in the entire rear bearing assembly and the idler pulley.
It is good maintenance, even if it does not completely solve your problem.
To reduce my Water Bill, can I adjust Shut Off Valve under Kitchen & Sink faucet (Heating, Ventilation, and Air Conditioning (HVAC))
by tester22 12/10/2023 10:59:21 AM(UTC)
bybilly (Refrigerator & Freezer Repair)
by bybilly 4/15/2018 7:54:56 PM(UTC)
bill (Dishwasher Repair)
by blevinsohn 11/15/2012 7:13:54 AM(UTC)
Bill caddigan (Dryer Repair)
by wcaddigan@aol.com 9/25/2011 4:50:44 PM(UTC)
Bill (Microwave Repair)
by Bill Witty 8/12/2011 11:07:02 AM(UTC)
Bill Benson (Oven Repair (including Ranges and Cooktops))
by bill19521 12/31/2010 10:35:27 AM(UTC)
2 & 1/2 yr old LG repair bill: $700.00!!!!!!!! (Washer Repair)
by 4estlakemom 8/9/2010 11:38:39 AM(UTC)
bill yovi (Oven Repair (including Ranges and Cooktops))
by bill yovi 7/23/2010 11:16:03 AM(UTC)
Bill K (Washer Repair)
by bkesler 1/12/2010 6:53:32 AM(UTC)
Uncle Bill (Oven Repair (including Ranges and Cooktops))
by UNCLE BILL 10/16/2009 9:28:34 AM(UTC)
Bill (Washer Repair)
by wvwoodchuck48 7/12/2009 10:18:06 AM(UTC)
bill summerville (Microwave Repair)
by summv 6/30/2009 12:02:57 PM(UTC)
Bill Lane (Dishwasher Repair)
by billlane501 5/1/2009 12:30:02 PM(UTC)
Bill Mac (Washer Repair)
by Bill Mac 1/22/2009 6:41:27 AM(UTC)
BillMac (Washer Repair)
by BillMac 12/4/2007 9:56:00 AM(UTC)
