jmtrevino45
#1 Posted : Tuesday, April 10, 2012 5:55:31 PM(UTC)
jmtrevino45
element light came on - have not noticed anything wrong. Is it possible that light comes on and nothing is wrong.
#2 Posted : Thursday, April 12, 2012 3:25:27 AM(UTC)
A model number may help others help you.
If you mean the element on light then odds are that the infinite switch needs replacing. Usually there are a set of contacts in the switch that turn this light on.
Having it on all the time is a safety hazard as you never know when the element is truly off.
If you mean the hot surface light then this is usually controlled by a thermostat under the cook top.
Maytag Gemini, element light won't turn off (Oven Repair (including Ranges and Cooktops))
by andygold 2/7/2011 2:49:19 PM(UTC)
Element light won't turn off (Oven Repair (including Ranges and Cooktops))
by bjonette 2/7/2011 8:42:14 AM(UTC)
Kenmore Element Light Stays Lit (Oven Repair (including Ranges and Cooktops))
by Pat123 1/11/2010 7:03:22 AM(UTC)
