2 Pages12>
debhug
#1 Posted : 16 years ago
debhug
Washer works fine except agitator is just moving very little as if belt has jumped off need to know how to open the washer up to find out if thats the problem :confused: need suggestions plz 7 cycle 2 wash spin speed if that helps
applianceman
#2 Posted : 16 years ago
applianceman
We need the model number for more accurate advice but the first thing to do is to try to turn the agitator by hand and if you can turn it the agitator coupling is bad. Pull the agitator up and out of the washer. Once off the agitator is right under the agitator attached to the transmission shaft with a 7/16 bolt. Clothes Washer Repair Guide
debhug
#3 Posted : 16 years ago
debhug
The model number is WJSR2070B2WW the agitator isnt responding as it should and moves too much when on the off mode ....it seems that the belt is still in tact cant get the washer open to check for sure....it seems it has dislodged from what holds it in place ...hope u understand this explanation .....what do i do to get the agitator off to check for dislodging because it does move but not like it should ....tyvm for any help with this cant afford a repairman must attempt to fix this myself:)
applianceman
#4 Posted : 16 years ago
applianceman
This is the part I think is your problem Part Details - GE Coupling, Agitator, part number: WH49X10042
Just pull the agitator up and you should see this part. If your can turn it by hand it is bad.
debhug
#5 Posted : 16 years ago
debhug
i cant get agitator off it wont come up ...is there something i need to do besides just pullup on it ....thanks Debbie
applianceman
#6 Posted : 16 years ago
applianceman
No, it just pulls off but it may be hard.
debhug
#7 Posted : 16 years ago
debhug
ok got the agitator off and the coupling screw or bolt is rusty ...when u said if i move it by hand its band...do u mean if i turn the whole thing its bad because the coupling isnt moving ...is it possible the agitator just worked itself loose from the coupling or jumped off ...its very dirty in there would cleaning it lock back into postion ???:confused:
debhug
#8 Posted : 16 years ago
debhug
i removed the coupling and it and the transmission shaft is caked with what i assume is soap scum so am cleaning all components then going to try putting it back together..then will know if its the coupling ...but it only movrs in circle with transmission shaft it doesnt slide on its own
debhug
#9 Posted : 16 years ago
debhug
alright i cleaned it all put it back on coupling and agitator all it is doing is slowly turning ...but it spins fine so im thinking its not the belt or the transmission ...would replacing the coupling make it move from side to side like its suppose to when its washing ?????
applianceman
#10 Posted : 16 years ago
applianceman
Yes the coupling may be your problem. When you got the agitator off did you try to turn the coupling by hand? If it will turn by hand the coupling is striped out. Does this machine spin or are you only having problems with wash?
Cafe fridge keeps warming up. Help! (Refrigerator & Freezer Repair)
by Guest 8 months ago
Dryer timer replacement help (Dryer Repair)
by Guest 9 months ago
Nursing Paper Review SOS: Help a Peer Out! (General Talk)
Diagnostic Code Help (I screwed something up) (Refrigerator & Freezer Repair)
by megarms 10 months ago
Freezer Help from Whirlpool Unit (Refrigerator & Freezer Repair)
by Guest 10 months ago
Door Switch Help With Samsung Microwave Model ME21M706BAS (Microwave Repair)
by clagrow 10 months ago
Need Help Identifying Part Manufacturer (Oven Repair (including Ranges and Cooktops))
by anonymous24 10 months ago
Help! Washing machine on repeat rinse cycle (Washer Repair)
by cali.poppy 10 months ago
Cant remove Samsung ice bin , need help please (Refrigerator & Freezer Repair)
by Orlando123 11 months ago
help maytag comercial dryer (Dryer Repair)
by blackwell316 11 months ago
HELP!!! Maytag Lat9604abe leaking from weeping holes in tub seal (Washer Repair)
by gocanada72 12 months ago
GE Frontload Washer - Trouble Shooting Help (Washer Repair)
by mahgnibb 12 months ago
Help finding the right screws to secure the top panel. (Washer Repair)
by mikkel3906z about a year ago
Dishwasher electrical help (Dishwasher Repair)
by Guest about a year ago
Washer help please maytag (Washer Repair)
2 Pages12>
