jon6180
#1 Posted : Thursday, January 17, 2008 8:30:25 AM(UTC)
jon6180
The bottom spray arms are not turning, there is water coming out of the holes but how much should be coming out. The water supply line to the unit was recently replaced. How hard should the water be coming out, how far should it spray out of the holes. If the water pressure is not the problem, what else could it be.
#2 Posted : Thursday, January 17, 2008 2:50:39 PM(UTC)
Remove the pump cover and the inlet protector.
Check the chopper for clog.
Bosch DW spray arms not turning (Dishwasher Repair)
by Max Headroom 8/28/2012 2:10:24 PM(UTC)
GE Quiet Power III spray arms not turning (Dishwasher Repair)
by alw 10/26/2008 7:08:30 PM(UTC)
