apphelp
#1 Posted : Thursday, August 27, 2009 5:44:52 AM(UTC)
apphelp
Water is dripping into the tub when the washer is off and not running. I assume I need either a gasket, o-ring, or valve inside the washer where the water enters the washer. Any ideas?
The only way to stop the drip is to turn off the water supply to the washer. Washer works fine with no other issues.
sidfink43
#2 Posted : Friday, August 28, 2009 5:53:34 AM(UTC)
sidfink43
You probably need a new inlet valve assembly. The part is inexpensive and easy to change out.
Part number: AP3094541
That should do it.
apphelp
#3 Posted : Friday, August 28, 2009 8:05:45 AM(UTC)
apphelp
Thank You - that was what I thought by looking at the washer. Thanks for validating my hunch.
Vintage Philco Freezer Advice (Refrigerator & Freezer Repair)
by Macbook 12/7/2016 1:00:21 PM(UTC)
phillips (Washer Repair)
by phillips 9/19/2009 10:34:38 AM(UTC)
Phil Goodwin (Dryer Repair)
by Phil Goodwin 4/20/2009 10:21:35 AM(UTC)
phillip (Refrigerator & Freezer Repair)
by phillip richard 3/8/2009 11:52:17 AM(UTC)
