Water is dripping into the tub when the washer is off and not running. I assume I need either a gasket, o-ring, or valve inside the washer where the water enters the washer. Any ideas? The only way to stop the drip is to turn off the water supply to the washer. Washer works fine with no other issues.
You probably need a new inlet valve assembly. The part is inexpensive and easy to change out. Part number: AP3094541
That should do it.
Thank You - that was what I thought by looking at the washer. Thanks for validating my hunch.
