No heat. The dryer runs and the timer advances. The igniter glows. No gas odor. The drum spins. Thanks for any suggestions.
If the igniter glows but no gas is coming then most likely the problem is a bad gas valve coils. - The coil kit Part number: AP4008890
Originally Posted by: Gene If the igniter glows but no gas is coming then most likely the problem is a bad gas valve coils. - The coil kit Part number: AP4008890
Thanks Gene. I appreciate the help. I thought it may have been the flame sensor preventing the gas. I'll give this a try! And thanks for the diagrams. Will I need any special tools to get at it?
You are welcome. A bad flame sensor is possible too but it happens more seldom. No special tools needed.
Gene, thanks again. You were right! Replaced the coils and got heat!
You are welcome. I'm glad you were able to fix it.
