dab
#1 Posted : Wednesday, August 26, 2009 8:12:37 AM(UTC)
dab
No heat. The dryer runs and the timer advances. The igniter glows. No gas odor. The drum spins. Thanks for any suggestions.
#2 Posted : Wednesday, August 26, 2009 3:14:16 PM(UTC)
If the igniter glows but no gas is coming then most likely the problem is a bad gas valve coils.
- The coil kit Part number: AP4008890
Here are the breakdown diagrams and Replacement parts for MAYTAG DG106 | AppliancePartsPros.com
dab
#3 Posted : Wednesday, August 26, 2009 4:35:35 PM(UTC)
dab
Thanks Gene. I appreciate the help. I thought it may have been the flame sensor preventing the gas. I'll give this a try! And thanks for the diagrams. Will I need any special tools to get at it?
#4 Posted : Wednesday, August 26, 2009 7:19:40 PM(UTC)
You are welcome. A bad flame sensor is possible too but it happens more seldom. No special tools needed.
dab
#5 Posted : Wednesday, September 9, 2009 5:13:53 AM(UTC)
dab
Gene, thanks again. You were right! Replaced the coils and got heat!
#6 Posted : Wednesday, September 9, 2009 3:24:58 PM(UTC)
You are welcome. I'm glad you were able to fix it.
Guest (5)
