Silvia Falgetelli
#1 Posted : Tuesday, August 25, 2009 8:55:37 AM(UTC)
Silvia Falgetelli
The problem is that when the washer is filling up dosen't stop the water coming in. For a while was making a noise in the spin cicle. Thne one day it didn't stop the water from coming in , and we had a mighty flood in the baseman.
Because of the age, 6 years, shoul we buy another?
sidfink43
#2 Posted : Wednesday, August 26, 2009 4:50:40 PM(UTC)
sidfink43
Hi Sylvia
Lets deal with the overflow problem.
If the water does not stop when you shut off the machine your water valves are stuck and will need to be replaced. An easy and inexpensive repair that you can do.
If the water does stop when you stop the machine, the problem is in the water level control system. The way it works is that there is a plastic tube from the water level switch down the side of the tub and when the water fills the tub it fills this tube. This increases the air pressure in the tube, and when the water is at the correct level it causes the water level pressure switch to click and tell the timer to stop the water.
You should first try cleaning out the plastic tube, take it off the water pressure level switch and blow it out. If this does not fix things replace the water level switch itself.
So, you should get your washer working ok, and then you can see if the noise in the spin is so great that you need a new machine.
WTW500DW1 wirlpool washer (General Talk)
by Ashley5791 2/13/2022 6:18:25 PM(UTC)
Wirlpool Centennial Washer (Washer Repair)
by 405husky 3/25/2020 8:51:06 AM(UTC)
Wirlpool 6ED22PKFXW01 (Refrigerator & Freezer Repair)
by Ady_E 1/3/2019 8:38:45 PM(UTC)
Wirlpool (Dishwasher Repair)
by taz_monster 8/6/2015 4:11:45 AM(UTC)
older Wirlpool dryer won't heat (Dryer Repair)
by automaticman 8/23/2014 4:48:43 PM(UTC)
wirlpool microwave (Microwave Repair)
by CFP 12/16/2013 5:28:13 PM(UTC)
wirlpool icemaker (Refrigerator & Freezer Repair)
by jimmy icemaker 1/30/2013 12:54:54 PM(UTC)
Wirlpool dishwasher upper arm not spinning (Dishwasher Repair)
by mogul397 12/13/2012 5:11:10 AM(UTC)
Wirlpool dishwasher will not stop cycling (Dishwasher Repair)
by dbarrett76 10/29/2012 12:02:26 PM(UTC)
wirlpool topload agitates but won't spin or pump motor hums (Washer Repair)
by curly33333 5/16/2012 6:51:35 AM(UTC)
Wirlpool Dishwasher Inlet Valve Voltage (Dishwasher Repair)
by nezoic 1/8/2012 10:05:22 AM(UTC)
my wirlpool washer wont spin (Washer Repair)
by cockroach 9/18/2011 8:26:39 PM(UTC)
Wirlpool Ultimate care II (Washer Repair)
by Peter R. 6/26/2011 1:07:57 PM(UTC)
Wirlpool Micorwave blows fuse when I press start magnetron or transformer (Oven Repair (including Ranges and Cooktops))
by wetpinkpants 10/2/2010 9:45:40 PM(UTC)
Need Wirlpool Mh3184xpy-1 tech sheet (Dishwasher Repair)
by wetpinkpants 9/30/2010 10:01:13 PM(UTC)
