I am unable to find the part number of the Inlet valve(s) for Wirlpool Centennial top load washing machine: #W10089728 AMTRIM-S I assume It's similar to this but there are many others...  Edited by user 5 years ago
| Reason: Not specified
Joined: 6/13/2014(UTC) Posts: 781   Was thanked: 1 time(s) in 1 post(s)
We need your model number, the number you gave is for your control panel. The model number of is located under the lid on the rim.
Thanks! I found the model number: Maytag MVWC300VM1 Sears has compatible part.
I'm glad you were able to locate the part. Remember that purchasing parts from here at Appliance Parts Pros affords you the opportunity of a 365 day return policy. Thank you for searching out your issue with us!
