I am not getting water to the ice maker or water dispenser. The farthest water goes is to the saddle connection right before the water valve. I took out the water valve and it seems clogged.
Can a water valve go bad? or can it be cleaned?
There are 2 electrical connections/or fuses[green] and [yellow] on top of the valve, are these needing replacement?
