ChrisMNS.Ut
#1 Posted : Saturday, August 22, 2009 9:06:33 PM(UTC)
ChrisMNS.Ut
I am not getting water to the ice maker or water dispenser. The farthest water goes is to the saddle connection right before the water valve. I took out the water valve and it seems clogged.
Can a water valve go bad? or can it be cleaned?
There are 2 electrical connections/or fuses[green] and [yellow] on top of the valve, are these needing replacement?
#2 Posted : Monday, August 24, 2009 11:51:50 AM(UTC)
