I have a Kenmore Gas Stove and last night the oven would not turn on. I turned the oven off and on a couple times, and then I heard the gas finally turn on and the oven heated up. I did a Google search and came across this forum, and it looks like my problem could be an ignitor??
I tried tonight and the pilot light up but I couldn't hear the gas come on and my oven doesn't work!
Any advice and feedback is appreciated? If it is an ignitor, are these difficult to replace?
Thank you, Mike
sounds like ignitor problem.easy to replace remove bottom drawer and you should be able to look up in there and its usually white unplug unit and remove and replace
