skidoomxz99
#1 Posted : Thursday, August 20, 2009 3:42:25 PM(UTC)
skidoomxz99
I have a Kenmore Gas Stove and last night the oven would not turn on. I turned the oven off and on a couple times, and then I heard the gas finally turn on and the oven heated up. I did a Google search and came across this forum, and it looks like my problem could be an ignitor??
I tried tonight and the pilot light up but I couldn't hear the gas come on and my oven doesn't work!
Any advice and feedback is appreciated? If it is an ignitor, are these difficult to replace?
Thank you,
Mike
guyster
#2 Posted : Tuesday, May 30, 2017 5:42:40 PM(UTC)
guyster
sounds like ignitor problem.easy to replace remove bottom drawer and you should be able to look up in there and its usually white unplug unit and remove and replace
