bsktcase1114
#1 Posted : 16 years ago
bsktcase1114
WE have a Maytag front loading dryer. It is barely over a year old. Worked fine and next day went to turn it on and it wont start. We have power and one or two of the red indicator lites seem to stay on an are very dim. What can we check to be the problem? We did check the breakers an such. It does have power an dryer light comes on. Totally confused, please help!
Frank / APP Team
#2 Posted : 16 years ago
Frank / APP Team
I believe the best thing for you to do with this issue would be to go the below link and read over the diagnostics and look at the wiring diagram. If you can narrow it down some I'm sure I can help you some more. It could very well be a simple repair but, it would really help if we know where you are or aren't getting power within the circuit.
If it appears to be something you still want to tackle and you can determine which part is bad we will gladly sell you what you need.
http://www.servicematters.com/d...0Sheet%20-%208563816.pdf
