rubiranch
#1 Posted : Wednesday, August 19, 2009 3:47:16 PM(UTC)
rubiranch
This unit leaked all of the freon out and I have repaired the leak.
The tag says 96 oz of R-12.
The low side it sitting at 26 psi and only cooling down to 10 degrees and it needs to be -5.
Before the leak it stayed between -5 and -10 but even after 4-5 days of running 9+ is the best it will do.
Any ideas?
rubiranch
#2 Posted : Thursday, August 20, 2009 4:14:18 PM(UTC)
rubiranch
can anyone tell me what the pressure should be on th elow side??
It is 26 psi and someone told me it should be as low as 3-4 psi.
