This unit leaked all of the freon out and I have repaired the leak.
The tag says 96 oz of R-12.
The low side it sitting at 26 psi and only cooling down to 10 degrees and it needs to be -5.
Before the leak it stayed between -5 and -10 but even after 4-5 days of running 9+ is the best it will do.
Any ideas?
can anyone tell me what the pressure should be on th elow side??
It is 26 psi and someone told me it should be as low as 3-4 psi.
