My problem started the other day. It works fine while washing but when it goes to drain it makes a very loud buzzing noise. I have checked the upper and lower bearing rings. PLEASE HELP!! The model number is DU930PWSB0 and it is a whirlpool.
Groups: APP Team
Hi. If you are mechanically inclined take the pump a part and check for foreign objects. If the noise is still there-replace the impeller kit. The impeller kit Part number: AP3115180
The other solution is to replace the motor/ pump assembly, which is much more money, but much less work and better chance of succeeding. The motor and pump assembly Part number: AP5306229
Groups: APP Team
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
