westermeyer25
#1 Posted : Monday, March 26, 2012 4:31:27 PM(UTC)
westermeyer25
My problem started the other day. It works fine while washing but when it goes to drain it makes a very loud buzzing noise. I have checked the upper and lower bearing rings. PLEASE HELP!! The model number is DU930PWSB0 and it is a whirlpool.
Simon / APP Team
#2 Posted : Monday, March 26, 2012 5:06:32 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
If you are mechanically inclined take the pump a part and check for foreign objects.
If the noise is still there-replace the impeller kit.
The impeller kit Part number: AP3115180
The other solution is to replace the motor/ pump assembly,
which is much more money, but much less work and better chance of succeeding.
The motor and pump assembly Part number: AP5306229
Here are the breakdown diagrams and Replacement parts for Whirlpool DU930PWSB0 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
Thank you. Post the results.
Simon / APP Team
#3 Posted : Monday, March 26, 2012 11:51:02 PM(UTC)
Simon / APP Team
Groups: APP Team
My pleasure.
Guest
#4 Posted : Thursday, May 13, 2021 2:48:25 PM(UTC)
Guest
Rank: Guest
United States
Did it work
