My maytag LSG7804AAE gas dryer does not heat up all the time. It only works after a break of a few hours between loads. The glow ignitor works fine but the gas dosen't come in, instead you hear a clicking noise and after a few seconds the ignitor turns off. Any idea?
Would it be the Hi-Limit Thermostat?
Originally Posted by: sruliz  Would it be the Hi-Limit Thermostat? No, I do not think so. If the high limit thermostat is bad, the igniter would not glow. Gene.
