sruliz
#1 Posted : Wednesday, August 19, 2009 11:11:19 AM(UTC)
sruliz
My maytag LSG7804AAE gas dryer does not heat up all the time. It only works after a break of a few hours between loads.
The glow ignitor works fine but the gas dosen't come in, instead you hear a clicking noise and after a few seconds the ignitor turns off.
Any idea?
#2 Posted : Wednesday, August 19, 2009 1:59:20 PM(UTC)
Most likely the problem is a bad gas valve coils (#7 & #8 on the diagram).
- The coil kit Part number: AP3094251
sruliz
#3 Posted : Friday, June 11, 2010 10:34:11 AM(UTC)
sruliz
Would it be the Hi-Limit Thermostat?
#4 Posted : Friday, June 11, 2010 4:08:16 PM(UTC)
No, I do not think so. If the high limit thermostat is bad, the igniter would not glow.
Coin operated Gas Dryer doesn't heat on 2nd cycle (Dryer Repair)
by sup 7/13/2017 9:44:31 AM(UTC)
Maytag Neptune Gas dryer doesn't heat (Dishwasher Repair)
by kmc1214 4/8/2011 8:00:44 AM(UTC)
Gas Dryer doesn't heat up - but that isn't my issue (Dryer Repair)
by mitch8 10/6/2010 11:04:27 AM(UTC)
