Coolhand
#1 Posted : Monday, March 26, 2012 5:05:13 AM(UTC)
Coolhand
My Dacor range beeps intermittently and shuts off any oven functions selected. Occasionally I can get the oven to start heating, and it may work for a while, then it beeps and shuts off. Sometimes the panel will say F1 or OFF, sometimes no error code. From reading other posts, I feel as though the main circuit board is at fault, but could there be other things to blame? It would be nice to have an oven again. Is it worth the repair? Is this problem due to heat exposure?
Simon / APP Team
#2 Posted : Monday, March 26, 2012 12:18:39 PM(UTC)
Simon / APP Team
Groups: APP Team
Hello.
You are looking at several possibilities. To find out which part
is at fault, please run the test.
You will need a multimeter.
Please check and post the results. Thank you.
Coolhand
#3 Posted : Tuesday, March 27, 2012 8:20:33 AM(UTC)
Coolhand
After reading the test instructions, I see that it refers to an F1 error. I have never had F1 as an error. The only display I ever get is F0 or OFF. Does the same test still apply?:confused:
Simon / APP Team
#4 Posted : Tuesday, March 27, 2012 10:34:59 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Proceed with the test. It will help you to check the membrane and ERC and relay board.
Post the results.
Coolhand
#5 Posted : Tuesday, March 27, 2012 2:26:36 PM(UTC)
Coolhand
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Post the results.
The membrane seems to be at fault, Thanks!
Coolhand
#6 Posted : Tuesday, March 27, 2012 3:02:13 PM(UTC)
Coolhand
It appears that the touchpad membrane is at fault.
Thanks,
Simon / APP Team
#7 Posted : Tuesday, March 27, 2012 4:04:53 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Do you need the part number?
Coolhand
#8 Posted : Saturday, March 31, 2012 2:42:50 PM(UTC)
Coolhand
Hi.
Yes please.
