My Dacor range beeps intermittently and shuts off any oven functions selected. Occasionally I can get the oven to start heating, and it may work for a while, then it beeps and shuts off. Sometimes the panel will say F1 or OFF, sometimes no error code. From reading other posts, I feel as though the main circuit board is at fault, but could there be other things to blame? It would be nice to have an oven again. Is it worth the repair? Is this problem due to heat exposure?
Groups ready for retrieval: APP Team
Hello. You are looking at several possibilities. To find out which part is at fault, please run the test. You will need a multimeter. Please check and post the results. Thank you.
After reading the test instructions, I see that it refers to an F1 error. I have never had F1 as an error. The only display I ever get is F0 or OFF. Does the same test still apply?:confused:
Hi. Proceed with the test. It will help you to check the membrane and ERC and relay board.
Post the results.
Originally Posted by: Simon / APP Team Hi. Proceed with the test. It will help you to check the membrane and ERC and relay board.
Post the results.
The membrane seems to be at fault, Thanks!
It appears that the touchpad membrane is at fault.
Thanks,
Hi.
Do you need the part number?
Do you need the part number? Yes please.
