bura123
#1 Posted : Monday, August 17, 2009 12:53:40 PM(UTC)
bura123
Hi, It appears that the thermostat has gone out of my unit. Initially, the cooling would kick on and off intermittently and now won't kick on at all. The MFG# on this is P1225104R. I talked to your customer service and found out that the original part number for this is 11043301 and has been updated several times. Is this the correct part/# that controls the thermostat and what is the current replacement part #? I found Whirlpool part # 96001035 that may replace the old number but the panel looks different. My unit has a 'high cool', 'low cool', 'high heat', and 'low heat' knobs/dials and the new panel shows only 'heat' and 'cool' pushbuttons.
Just trying to trackdown the correct part. Thanks for your help!
Control board question (Refrigerator & Freezer Repair)
by hrlydavison 3/19/2013 10:11:14 AM(UTC)
Control board question (Oven Repair (including Ranges and Cooktops))
by redpoint513 12/11/2012 9:00:33 AM(UTC)
