Hi, It appears that the thermostat has gone out of my unit. Initially, the cooling would kick on and off intermittently and now won't kick on at all. The MFG# on this is P1225104R. I talked to your customer service and found out that the original part number for this is 11043301 and has been updated several times. Is this the correct part/# that controls the thermostat and what is the current replacement part #? I found Whirlpool part # 96001035 that may replace the old number but the panel looks different. My unit has a 'high cool', 'low cool', 'high heat', and 'low heat' knobs/dials and the new panel shows only 'heat' and 'cool' pushbuttons.
Just trying to trackdown the correct part. Thanks for your help!
