Hi, I need to know if ordering the dual water inlet valve kit could rectify the problem of no water making it into the icemaker. The water in the door (drinking) is working just fine. The ice maker is cycling. I have researched the part...# is AP3085178 (2188542). Do you think this might be the problem?:)
If the water feeding tube into the ice maker (inside the freezer) is not blocked with an icicles and/or frost then most likely the water valve is the culprit. The water valve Part number: AP3085178
