cjames
#1 Posted : Thursday, March 22, 2012 6:16:15 AM(UTC)
cjames
I have a F3 code flashing on GE microwave, model# JVM1851BD002. My microwave and is now locked up. I think I need a new Switch Membrane, part# AP3187461. Is this correct and how hard is it to replace?
Simon / APP Team
#2 Posted : Thursday, March 22, 2012 10:43:13 AM(UTC)
Simon / APP Team
Groups: APP Team
Hello.
You are right F3 means bad touch pad (membrane).
The membrane Part number: AP3187461
To replace it first unplug the unit.
Take off top grill (slide it to the left after taking screws out and pull out).
Take one screw out on the top of the control panel, lift it and
take out.
Take out the control board and membrane. Peal off protective cover and attach new membrane.
Reassemble the unit.
Thank you. Post the results.
cjames
#3 Posted : Thursday, March 22, 2012 10:46:16 AM(UTC)
cjames
Thank you very much.
F3 Code (Oven Repair (including Ranges and Cooktops))
by GFU125 12/15/2015 1:14:03 PM(UTC)
by GFU125 12/15/2015 1:13:50 PM(UTC)
Frigidaire Oven F3 code (Oven Repair (including Ranges and Cooktops))
by gdeanrussell 9/7/2013 6:31:35 AM(UTC)
Whirlpool Gold Oven - E2F3 Code and Broiler Comes on by itself!! (Oven Repair (including Ranges and Cooktops))
by Kentuckypunk 12/11/2012 5:44:12 PM(UTC)
Thermador Dual fuel range oven door locked and f3 code. (Oven Repair (including Ranges and Cooktops))
by mikey77 7/28/2012 7:14:51 AM(UTC)
E2-f3 Code Flashed Onto Display (Oven Repair (including Ranges and Cooktops))
by Todd Reka 6/5/2012 4:24:13 PM(UTC)
f3 code on maytag mer5730 (Oven Repair (including Ranges and Cooktops))
by fastfreddy 7/12/2011 11:21:58 AM(UTC)
by backatya07 4/16/2011 3:18:47 PM(UTC)
ge oven f3 code (Oven Repair (including Ranges and Cooktops))
by gusjac 2/20/2011 3:43:58 PM(UTC)
GE wall oven F3 code (Oven Repair (including Ranges and Cooktops))
by psquire 12/18/2010 3:28:41 PM(UTC)
Still Getting an F3 Code after heat sensor was replaced (Oven Repair (including Ranges and Cooktops))
by Scott Carlson 8/16/2010 6:39:04 AM(UTC)
oven not heating well, f3 code after replacing temp sensor (Oven Repair (including Ranges and Cooktops))
by jenna99 3/3/2010 11:50:54 AM(UTC)
Spacemaker XL1800 has F3 code (Microwave Repair)
by Cherrystro 10/15/2009 8:07:32 AM(UTC)
Stove F3 Code (Oven Repair (including Ranges and Cooktops))
by batesy 2/22/2009 11:47:12 AM(UTC)
F3 code in Whiprool oven (Oven Repair (including Ranges and Cooktops))
by aranala 2/18/2009 12:10:35 PM(UTC)
