bigrubee
#1 Posted : Sunday, August 16, 2009 6:29:28 AM(UTC)
bigrubee
I recently moved when we hooked up the gas range it will not ignite The stove was installed new buy the store we bought it from it is set up for L.P. The gas at our new residence is also L.P. The ignitor clicks and sparks and the gas flow is not obstructed at the valve, I don't seam to be getting gas to the burners. Any ideas ? I would be greatfull.:confused:
Dan O.
#2 Posted : Monday, August 17, 2009 10:22:31 AM(UTC)
Dan O.
Quote:
I don't seem to be getting gas to the burners
no gas to ANY burner, not surface nor oven?
Whom disconnected it for you?
If you're not getting gas to ANY burner, there may be a main shut off valve in the stove. Sometimes it is on the gas regulator itself. A licensed installer might have shut that valve off before uninstalling.
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
bigrubee
#3 Posted : Monday, August 17, 2009 4:04:02 PM(UTC)
bigrubee
I was present when the stove was disconnected. drove to new location, hooked it up the way it was hooked up and I have nothing.
Dan O.
#4 Posted : Thursday, August 20, 2009 10:59:03 AM(UTC)
Dan O.
Great!
Whom disconnected it and did they turn off a main gas valve in the range (if present) before doing so (if in fact NONE of the burners (not surface nor oven) are getting gas - which you still haven't clarified BTW).
JMO
Dan O.
=D~~~~~~
bigrubee
#5 Posted : Thursday, August 20, 2009 6:26:40 PM(UTC)
bigrubee
nothing in the stove was turned off and correct niether burners or oven will light,also to to clarify we disconnected it at the gas supply I didn't hire anyone to do that for me.
Dan O.
#6 Posted : Saturday, August 22, 2009 7:23:36 AM(UTC)
Dan O.
No gas smell either??
If you're not getting any gas to any burner and no one turned off a main gas valve inside the stove, then you'll have to check your house gas supply as that is the only other thing that would affect gas flow to ALL burners at the same time. It's not a problem with the range.
JMO
Dan O.
=D~~~~~~
