vulcanman
#1 Posted : Saturday, August 15, 2009 2:37:01 PM(UTC)
vulcanman
My maytag top loader at first developed a no/slow spin problem. Now it agitates while it spins on spin cycle. this is a 3 year old machine and does not have, (at least externally) a solenoid to shift from agitate to spin. Brand new belt.
What next?:confused:
sidfink43
#2 Posted : Monday, August 17, 2009 6:11:21 AM(UTC)
sidfink43
This is somewhat of a mystery, and I do not think I can give you a definitive diagnosis.
The thrust bearing failure is a typical problem on these machines, and I would start there with a replacement.
Here is the service manual.
http://www.servicematters.com/m...ibrary/docs/16026502.pdf
It will also give you some additional trouble shooting areas to check.
Good luck.
Maytag spin problem (Washer Repair)
by kingbrewster 1/12/2012 7:07:36 AM(UTC)
maytag spin problem (Washer Repair)
by djcrazytaxi 3/25/2011 7:33:12 PM(UTC)
Maytag Spin Problem (Washer Repair)
by big red 2000 12/26/2007 8:15:30 AM(UTC)
