jbaillie
#1 Posted : Tuesday, March 20, 2012 1:15:44 PM(UTC)
jbaillie
I am trying to determine if my control panel failed. The briol element failed 1 night with a loud noise. After checking it was completely burnt in 1 spot. I replaced it but the oven still does not heat.
I'm not getting 220 volt to the bake or broil element from the control panel. The red/wht & blue or red&yellow both put out about 115volts ( I forget if the oven was on or not). They both read about 15 or 16 uhmes. Should I see 220 volts to each element when I turned it on to broil?
#2 Posted : Tuesday, March 20, 2012 3:01:58 PM(UTC)
The normal voltage reading at any of the heating elements (while the control calls for heat for that element) suppose to be about 240 VAC between the wires connected to that element terminals.
If the reading is incorrect, then the control board has to be replaced.
- The control board Part number: AP4511511
