dougbeckley
#1 Posted : Saturday, August 15, 2009 10:07:46 AM(UTC)
dougbeckley
Hello,
I'm replacing part # 455 (pump connect) on a GE gsd1200t55 dishwasher.
It is part of the motor-pump mechanism. It's location in the dishwasher can be found on Appliancepartspros.com website under the "motor-pump mechanism" diagram. The part has internal threads that interface with the external threads of part #550 (found on the same diagram). Part number #550 sits inside the dishwasher tub; part #455 sits underneath the dishwasher tub. The floor of the tub is sandwiched between the two parts. Do I need a sealant of some sort between the threads of these two parts?
Thank you for any advice,
Doug Beckley
applianceman
#2 Posted : Sunday, August 16, 2009 10:46:48 AM(UTC)
applianceman
No, just make sure it is good and tight and it shouldn’t leak. GE Dishwasher Pump Leaking Repair Guide
dougbeckley
#3 Posted : Tuesday, August 18, 2009 5:01:48 PM(UTC)
dougbeckley
Thank you for your help.
