Hello,
I'm replacing part # 455 (pump connect) on a GE gsd1200t55 dishwasher. It is part of the motor-pump mechanism. It's location in the dishwasher can be found on Appliancepartspros.com website under the "motor-pump mechanism" diagram. The part has internal threads that interface with the external threads of part #550 (found on the same diagram). Part number #550 sits inside the dishwasher tub; part #455 sits underneath the dishwasher tub. The floor of the tub is sandwiched between the two parts. Do I need a sealant of some sort between the threads of these two parts?
Thank you for any advice,
Doug Beckley
Thank you for your help. Originally Posted by: applianceman
