Washer has given no indications of failing and just stopped after the agitation cycle. The lid is down and it is getting power. Thoughts? :)
At the end of the agitation cycle when it stops, lift up the lid and see if it goes into the spin cycle. If it does, replace the timer.
If it does not, check the lid switch which is probably the problem.
Good luck.
It was the lid switch bypassed it...problem solved. Thanks!
Great, glad that worked and thanks for updating us.
I've got pretty much the same problem (same model and everything), except mine only stops on Super Size loads (medium and small complete every time). Would this still be the lid switch or should I check something else?
Could you please start a new thread and list your model number, brand a good description of the problem. This will allow other people to view your post and the resolution of your problem.
It sounds like what you are saying is that if you set your water level to super size load the machine will stop after the agitation, but that this does not happen at other load/waer level settings? If that is the case that is very unusual, so let us know exactly what is happening. If you lift the lid and put it back down does it start up? If you manually advance the timer a notich will it continue?
Originally Posted by: sidfink43  Could you please start a new thread and list your model number, brand a good description of the problem. This will allow other people to view your post and the resolution of your problem.
Thanks okay, just posted a new message ... =)
