R&S123
#1 Posted : Saturday, August 15, 2009 9:34:24 AM(UTC)
R&S123
Washer has given no indications of failing and just stopped after the agitation cycle. The lid is down and it is getting power. Thoughts? :)
sidfink43
#2 Posted : Sunday, August 16, 2009 6:05:52 AM(UTC)
sidfink43
At the end of the agitation cycle when it stops, lift up the lid and see if it goes into the spin cycle. If it does, replace the timer.
If it does not, check the lid switch which is probably the problem.
Good luck.
R&S123
#3 Posted : Sunday, August 16, 2009 12:59:21 PM(UTC)
R&S123
It was the lid switch bypassed it...problem solved. Thanks!
sidfink43
#4 Posted : Sunday, August 16, 2009 1:01:35 PM(UTC)
sidfink43
Great, glad that worked and thanks for updating us.
dvdbarnyard
#5 Posted : Thursday, March 11, 2010 8:39:30 AM(UTC)
dvdbarnyard
I've got pretty much the same problem (same model and everything), except mine only stops on Super Size loads (medium and small complete every time). Would this still be the lid switch or should I check something else?
sidfink43
#6 Posted : Thursday, March 11, 2010 12:53:42 PM(UTC)
sidfink43
Could you please start a new thread and list your model number, brand a good description of the problem. This will allow other people to view your post and the resolution of your problem.
It sounds like what you are saying is that if you set your water level to super size load the machine will stop after the agitation, but that this does not happen at other load/waer level settings? If that is the case that is very unusual, so let us know exactly what is happening. If you lift the lid and put it back down does it start up? If you manually advance the timer a notich will it continue?
dvdbarnyard
#7 Posted : Thursday, March 11, 2010 1:26:32 PM(UTC)
dvdbarnyard
okay, just posted a new message ... =)
Guest (4)
Roper washer won't complete cycle for Super Size Load (Washer Repair)
by dvdbarnyard 3/11/2010 1:25:45 PM(UTC)
