AppliancePartsPros.com
Appliance Repair Help
Washer Repair
washer won't spin during rinse already changed coupler
The washer won't spin the tub during the rinse cycle. Everything else seems to be working normally. I've already changed the coupler. It didn't help. Now there is a burning rubber smell but I cant see anything wrong.
Remove the motor and check how the transmission shaft is moving in both directions. Make sure the both parts of the coupling are aligned properly.
Washer Repair
