cmk461
#1 Posted : Friday, August 14, 2009 6:43:50 AM(UTC)
cmk461
The washer won't spin the tub during the rinse cycle. Everything else seems to be working normally. I've already changed the coupler. It didn't help. Now there is a burning rubber smell but I cant see anything wrong.
#2 Posted : Friday, August 14, 2009 4:18:59 PM(UTC)
Remove the motor and check how the transmission shaft is moving in both directions. Make sure the both parts of the coupling are aligned properly.
