AppliancePartsPros.com
Appliance Repair Help
Washer Repair
1993 GE top-load washer- fills w/water; won't agitate or drain
I have a GE top-load 7-cycle, 2 speed washer with mini-wash; heavy duty extra large capacity washer -- built 1993 or before. Fills with water but won't finish the cleaning cycle -- no agitation and won't drain. There is no model number referenced anywhere, including on the inside of the lid. No way to see if model # is referenced on the back of the machine. Any idea on what could be wrong or how to trouble-shoot?
You may need a new motor. since the motor pumps the water out.
Would this also have a relay and is it possible that could be the problem too --
Washer Repair
