ice maker stoped getting water. I ordered a complete valve set and replace it. still no water coming in. ordered a new ice maker last monday and installed it. it goes through the motions but still no water. I have ohm checked the valves and all registered between 248-458. I have checked the power coming in to the ice maker and it gets well over 110 volts. it is a new ice make. is it possible it has a bad water control micro switch. if so what are my options??? Vahan
