Tom John
#1 Posted : Thursday, August 13, 2009 7:44:37 AM(UTC)
Tom John
The dishwasher controls stopped working. It displays a blinking light next to the "Normal" button on the control panel. The front panel displays two dashes. I checked all connections on the control panel and door switch plus killed the power in an attempt to reset. Nothing worked. I bought a new electronic control and now I get just the blinking light next to the Normal button on the contro panel. It just seems to be locked up. What should I check or replace? I'm thinking about replacing the consule, but hate to just replace parts until I finallly find it.
Dennis monte
#2 Posted : Friday, August 14, 2009 3:27:16 PM(UTC)
Dennis monte
I have the same problem and have also changed out the control mod. What do I need to replace?
caryuri
#3 Posted : Tuesday, August 18, 2009 3:26:20 PM(UTC)
caryuri
Originally Posted by: Tom John Go to Quoted Post
The dishwasher controls stopped working. It displays a blinking light next to the "Normal" button on the control panel. The front panel displays two dashes. I checked all connections on the control panel and door switch plus killed the power in an attempt to reset. Nothing worked. I bought a new electronic control and now I get just the blinking light next to the Normal button on the contro panel. It just seems to be locked up. What should I check or replace? I'm thinking about replacing the consule, but hate to just replace parts until I finallly find it.[/quote
HI I have the same problem with my dishwasher, if is possible can you tell me if you replace the console and this fixed the problem?
thanks for you advise.
Tom John
#4 Posted : Tuesday, August 18, 2009 3:40:43 PM(UTC)
Tom John
I have not changed the consule because the cost is nearly $200. I'm trying the fuse kit first, it's only $12. If this doesn't work I have to consider buying a new dishwasher versus putting $400 of trial and error into this 5 year old dishwasher. This is not what I expected when buying a KitchenAid...
