slipjig
#1 Posted : Saturday, March 17, 2012 5:44:45 PM(UTC)
slipjig
please help!!!
my washer fills up. begins to agitate with each agitation it goes clank! clank! clank! at a rather slow process.then at the spin cycle.it wont spin but sound likes a high speed drill from hell really loud.the water empties but wont spin.
any answers ?
thank you
Simon / APP Team
#2 Posted : Saturday, March 17, 2012 10:14:11 PM(UTC)
Simon / APP Team
Groups: APP Team
Hello.
From the clunky clank sounds you are describing I should point you to the coupling assembly. There is the chance it could be something ells but I would stick with coupling.
It's located between the motor and the transmission.
The motor coupling Part number: AP3963893
On the diagram#3 position#13.
Here are the breakdown diagrams and Replacement parts for Whirlpool WTW5521SQ0 AUTOMATIC WASHER | AppliancePartsPros.com
Please post the results and thank you.
GE Washer with bad transmission? (Washer Repair)
by fljlee3 1/16/2024 10:50:07 AM(UTC)
How to test a direct-drive transmission? (Washer Repair)
by DIY_Again! 3/20/2023 9:12:52 AM(UTC)
Ruined 3 splutches, problem was the transmission (Washer Repair)
by Greg Shay 9/28/2022 5:52:48 AM(UTC)
Maytag top load washer leaking oil from transmission (Washer Repair)
by Rdchapman2 2/27/2022 1:15:02 PM(UTC)
Whirlpool Cabrio Washing Machine replaced transmission (Washer Repair)
Belarus reggiebliss 8/26/2021 7:31:39 PM(UTC)
Can't pull out Motor/Transmission in Whirlpool Washer (Washer Repair)
by TWash2 6/16/2021 6:42:02 PM(UTC)
Whirlpool Washer LSQ8543JT1 Transmission Gear (Washer Repair)
by wvdiesel 2/20/2021 9:55:50 AM(UTC)
Maytag Top-Loading Washer Transmission Issue? (MVWC565FW) (Washer Repair)
by Beerski 11/13/2020 10:59:24 AM(UTC)
Speed Queen washer transmission repair (Washer Repair)
by thorning 4/2/2018 11:07:15 AM(UTC)
Clearing hole in new transmission (Washer Repair)
by Jimbobaloue 3/28/2018 6:23:59 PM(UTC)
Motor or Transmission (Washer Repair)
by asd643 10/3/2017 1:09:42 PM(UTC)
Kenmore Washer, Suspect transmission (Washer Repair)
by jmrec100 5/12/2017 3:03:16 PM(UTC)
Transmission Oil Type (Washer Repair)
by RdPope01 7/13/2016 5:43:30 AM(UTC)
Kenmore washer leaking water on transmission (Washer Repair)
by arttruji 6/30/2016 11:55:27 AM(UTC)
Maytag Washer - Transmission Gear Oil & Sealant (Washer Repair)
by rips 4/17/2016 6:15:08 PM(UTC)
