2 Pages12>
miked35
#1 Posted : Saturday, March 17, 2012 5:14:40 AM(UTC)
miked35
I replaced the evaporator fan motor due to excessive noise. frig would not shut off after this, however freezer temp is 4degrees and frig temp is 36-40 degrees and fresh food bins temps are well below 32 degrees. i replaced the frig thermostat, same problem , frig wont shut off . please advise.
Thanks Mike D
#2 Posted : Saturday, March 17, 2012 8:41:15 AM(UTC)
Is the evaporator fan blade turning the right way? It is shaped to cup the air and blow it away from the motor and into the fridg and freezer sections.
miked35
#3 Posted : Saturday, March 17, 2012 11:37:59 AM(UTC)
miked35
how do i reverse the blades direction?
Mike D
#4 Posted : Sunday, March 18, 2012 12:31:20 AM(UTC)
Either replace the blade with the correct one, or take the motor apart, if possible, and reverse the armature.
miked35
#5 Posted : Sunday, March 18, 2012 5:26:07 AM(UTC)
miked35
i was able to change the fan blades direction as recommended, however the frig still stayed on even after reaching 39degrees on top shelf and 21 degrees inside the bottom fresh food bins. the freezer temp is 4 degrees. the frig has run in excess of 18 hours without stopping since making the change of the evaporator fans direction of flow. what else could keep the compressor on continually?
thanks for your input
Mike D
#6 Posted : Sunday, March 18, 2012 6:52:12 AM(UTC)
Remove the lower crisper drawers and push in the door switch if needed to start the fan. If cold air is blowing out the lower vent, you have the air flow reversed, must have mounted the fan motor upside down!!
miked35
#7 Posted : Sunday, March 18, 2012 7:46:42 AM(UTC)
miked35
at this point i have had the fan orienated both directions of flow. i saw in the schematic that there is a contact in the defrost timer that must be made for the compressor to work. is that a possibility?
thanks
mike d
#8 Posted : Sunday, March 18, 2012 8:41:15 AM(UTC)
The evaporator fan motor must blow cold air from the freezer into the upper
vent in the refrigerator so the cold control gets cold air directly from the freezer. If not, the fridg will never shut down.
miked35
#9 Posted : Monday, March 19, 2012 4:08:24 AM(UTC)
miked35
thanks for your input rich. stiil the same situation, frig wont cut off. it is a side by side. i have tried all that you suggested. like i mentioned before i have reversed the evap fan direction with the frig still not cutting off. any thing else to look for?
Mike D
#10 Posted : Monday, March 19, 2012 6:36:23 AM(UTC)
Verify the cold control will turn off the compressor. If so, that's probably ok, then measure the stabilized freezer temperature and post.
2 Pages12>
