River Rat
#1 Posted : Friday, March 16, 2012 6:23:08 PM(UTC)
River Rat
My problems is this, my washer does not spin dry the clothes. I went to your site and they indicated the problem could be the motor coupling. I just took the motor coupling off and the part does not look like anything is broken. Could it still be defective?
sidfink43
#2 Posted : Sunday, March 18, 2012 5:50:36 PM(UTC)
sidfink43
Make sure you check all three pieces of the coupling.
If the machine will agitate but not spin the coupling is not the problem. In that case the clutch/brakes are most likely the issue. See the Sticky by Richappy at the top of the main washer page for more info.
